Dopp Creek
While I am waiting for my transmission
parts I thought I would replace the u-
joints in the front and rear driveline.
The front shaft from the transfer case to
the front axle had the caps standing proud
of the yoke about .030 and 90 degrees to
that the caps fit snugly in the yoke as
they should. When I pushed out the cross,
I found snap ring grooves about half way
in the yoke. I have not seen a u-joint
that was not secured with clips. I had the
auto parts guy pull up the specified joint
and it was the same dimension as the one I
removed. I also noted this strap affixed
to the two caps that are secured in the
yoke. Can someone tell me what I have and
if they run u-joints without clips?
The light bands on the 12:00 & 6:00 caps
are where the grooves are in the yoke.
