951 Powermatic Ford
I have a 951 Powermatic Ford on LP with a serial number of 46222 which makes it a 1958 model. Did this tractor come with factory LP? My question raises a concern regarding the hood and fuel tank. There are gaps between the front of the tank and the tractor just above the radiator and also at the rear of the tank before reaching the dash area. Didn't know if factory LP came that way. Thanks for any responses.
Just above the serial number, there should be a model number. Most factory LP-powered Fords of that era would have a '-L' after the model number. (951-L, in your case) If you can post some pictures, some of the guys on the Ford forum who are familiar with the LP models could probably tell you if it's factory.
And I'm sure someone will correct you... It's a Powermaster.
951 would be a five speed, row crop model. There is no model with the name Powermatic, however its common to see the Ford tractors with select-o-speed transmissions referred to erroneously, with names other than the previous, but most will know what you are talking about anyways LOL!
There was a powermaster name for some of the general purpose tractors, as well as a workmaster name, 601 and 801 general purpose tractors.
The name you used above would lead someone to think about this tractor being a select-o-speed, but the model does not match, and its stamped on the transmission housing, near the starter.
On the LP, yes there are Factory LP models, and they are referred to in the Ford Shop Manual, I will include a few photos to help you determine what you may have there.
The Workmaster and Powermaster names covered both utility (general purpose) and rowcrop models. The Workmasters (501, 601, and 701) had a 134 c.i. gas or LP or 144 c.i. diesel engine; the Powermasters (801 and 901) all used 172 c.i. engines, whether gas, LP or diesel.
