Well, neither my 960 or either of my 961s ever overheated so it must be possible to solve the problem. Rather than a lot of Q and A, how about some history such as how long have you had it, for how long has it overheated? How are you using it, and what have you tried so far. They don't charge us extra here for using more words.
Many ways to fix it, depending on the cause.
First, what are the symptoms? Does the radiator actually boil over, or does the temperature gauge show that it's hot but you haven't actually verified that it is correct?
Bad distributor was our issue when we went through that for a year. Messed up timing from the worn distributor had it overheat.
They run hot anyhow if you actually use them for real work, moving the muffler out, routing/ protecting the fuel line, and moving the coil out away from the block an inch
or two all help.
Paul
clean radiator fins, wash out with garden hose, not pressure washer
flush radiator and block, refill with 50/50
set timing to factory
adjust carb, not too lean
Mowing?
After market radiator?
Expect radiator to rapidly clog with debris when trying to mow with radiator without proper flat-finned industrial core.
overhauled motor last year, new radiator, new water pump , i want to use with 7 foot haybine, good for about 30 mn then actually boils over, works slightly better when cooler out as under 80 degrees, i agree that if yours dont over heat there must be a way
Ive heard the after market radiators arent what they should be. I have no personal experience but what I hear.
Might be part of your issue, the radiator fits and cools for a parade tractor, but not sized right to cool a hard working
tractor?
Im probably not being helpful, but hoping to bring out possibilities for you.
Paul
I bought tractor last year, some noise in motor but ran ok, except for heating, noise got worse , so pulled head, number 3 piston was broke with piece broken off, so in frame overhaul, radiator from yesterdays tractor parts not sure if aftermarket. will rebuild carb, put new thermostat, already change antifreeze, as long as i know its might be possible to get to work ill keep at it,, I was ready to give up and put in auction,, thanks for help
I suspect the aftermarket radiator is your
problem. I had to replace the one on my
851 last year. It held one gallon less
than the old one. I just piddle around
with it now a day's and it's OK but I'm
sure it would overheat if worked hard. The
only reason I didn't have the old one
recored was the tanks were shot.
When you say 'overheats', what exactly is it doing, and when does it do it?
Does the temperature gauge slowly rise until it's in the red, then the radiator boils over? Or does it quickly start blowing water before it's had time to warm up? The former is 'overheating', while the latter indicates a blown head gasket or similar problem, such as air trapped in the cooling system.
Does it only overheat while under heavy load? That would indicate a possible defective radiator. If it's overheating under light load or no load, I doubt it's a bad radiator.
as i am cutting hay the temperature on gauge slowly rises to go into the red, i would say under load when air temp is around 70 to 80 degrees approx 1/2 hour, even raking hay it will just take a little longer, radiator will boil out fluid. this fall i tried plowing with it, 15 min and i was done, overheated, air temp was 55 degrees
My 860 started overheating. Blew steam from the pressure cap one day. I found thermostat wasn't opening. I ordered a brand new one from this site. I checked it on the stove - didn't start opening until 210, was supposed to be a 180. Second one I got was OK. Moral of the story, always check a new thermostat 'cause there's some bad ones out there.
Mine have never overheated while raking. I would take your infrared thermometer and check all over the engine hoses, radiator. This should enable you to narrow it down.
Radiator definitely aftermarket. OEM radiators NLS for decades. Best solution if original radiator cannot be repaired is to recore with proper flat-finned industrial core.
Did you inspect/change water pump?
Not uncommon to find impellers worn due to age/coolant comtamination/multiple rebuilds. Worth a look.
(quoted from post at 06:51:12 11/28/23) Radiator definitely aftermarket. OEM radiators NLS for decades. Best solution if original radiator cannot be repaired is to recore with proper flat-finned industrial core.
Mark told us that he put a new one on.
