960 parts manual?
DKase
Does anyone have a 960 parts book that you could look up a part for me? I installed the power steering from a 960 on my 930. The "motor" or what ever it is called that is hooked to the steering wheel is leaking out the shaft seal. I was told once it is a Ross system. Is that true? I have a good hydraulic shop locally, but I need to be able to tell them what it is. Part number for the "motor", or number for a shaft seal kit would be helpful. Thanks DK
No mfg in the book,, let me know if you need a whole unit I have plenty here is from the 960 parts
Thanks Tom! I will see if the part numbers get me anywhere. I dug through my parts building today and I think I found a spare to use for now.
Please get back & let us know how this works out, hopefully with some pictures. A lot less weight on the steering axle of a 960 than is what is on a 930. Is the 930 a 6sp or 8sp? Very interesting challenge either way.
FYI it is a MAD series Ross system. Case has the seals on hand, so they must also be used in something newer than these. Hydraulic shop can supply the seals by matching them up.
