matt bock
I looked at a 9600 yesterday run good under load but has a miss at idle that comes and goes has sims inj pump no blowby do these have much injector problems or is this in the pump? Also shifter is a little sloppy how hard is that to fix? thanks
Check the oil in the pump cam box. That can tell you about how it has been serviced. There are a bunch of wear points in the shift linkage. There are some parts that can be readily replaced to tighten it up.
