961 Ford diesel
Larry@bwxt
I am having the injection pump rebuilt on my 961, Thought I would have the injectors checked also ,just wondered if the water jacket liner between the injector and the cylinder head could possibly come out with the injectors or does it have liners. Older IH engines did and then the coolant runs into the cylinder
I never read anything about a liner in them. You just unbolt the injector and pull it. you need to stick a screwdriver into the copper washer at the bottom and replace them. Make sure you check those seats under the washer for any scoring. I had a man rebuild a head for me and I think his son was his helper. At the bottom of one hole it looked like someone didn't quite tighten the injector to spec. It looked like it had a high pressure leak scoring a line from the hole in the middle towards the outside edge.
Thank you for the reply, I have pulled injectiors out and the liners came out, glad these don’t have them
Larry Choate
