(quoted from post at 12:50:28 04/03/21) I've got two 901's, both have sleeves - I read somewhere that the sleeveless engines started with the 4000 models (4 cylinder).
(quoted from post at 08:50:32 04/05/21) Thats not the case showcrop. The diamond are used on
sleeveless tractors too. They are there to mark the beginning
and end of the serial number. It wasnt until the late 01 series
that the sleeveless block appeared. The quickest way to tell is
if has a canister oil filter or an adapter to a spin on it should
have sleeves. If it is a casted boss for a spin on oil filter than it
is sleeveless.
(quoted from post at 15:07:10 04/05/21) If you want to get real technical yes some sleeveless blocks could have sleeves but they probably would be bore to fit repair sleeves and not the original removable ones found in the sleeved motors. And I doubt there are many that way out there. My statement was a general statement that it is easy to tell what it should be by the oil filter
