Uh Oh
would anyone by chance have the seal numbers for the pto seal and the planetary seal at the back axle shaft? tried the local parts store but they arent showing anything. thanks in advance
Here's the PTO seal number for the single speed PTO, D9NN703BB. Check the link below for the other seal. When you get there scroll down to Parts Search and click, then put in your tractor model and click, then select the component. Hope it helps.
Parts
that pto seal will/should be a stock item at a chh dealer.. same seal fits quite a few models for a large time period. any time I pull a pto shaft I always slap a seal in.. to cheap and easy not to.. and I've never had to order one.. dealer always had a drawer of them in stock... new ones look different than the oem ones.. spring and inner lip to oil though and you are good..
soundguy
