966 Temp Guage
Not sure if I have a bad guage or sensor or if it is normal. During cooler weather, I can let it sit to warm up, but temp guage doesn't move. When hooked to and implement and working ground, it goes all the way to hot. Doesn't seem to be a mid point that looks to be normal operation temp. Is this normal or do I need to do some fixing?
The problem may be elsewhere than the sensor or the gauge. Depending on where the sensor is located you may not see any temperature rise with the thermostat closed. When you work the engine hard enough to make the thermostat open it may be overheating due to a clogged radiator, bad pump, clogged passages in the engine, etc.
