970 case with loader
cwiles
I just bought a 970 agri king case that has a loader. The loader has 2 lines ran to the back aux hook ups. I will need all 4 aux hook ups for my baler and was wonder if I could change the location of the loader hook ups and what would I need?
You might try posting this on the case forum . There would be a better chance of getting the answer you are looking for.
If you would be able to get some pictures of what your's looks like I might be able to figure it out. I have seen a couple different ones but the pictures are not clear on how the lines run.
I am only going to post this one time! the only PROPER way to add a valve between the pump and the flow divider is to have a power beyond valve with a case drain back to sump. If not done that way if the remotes are stroked on the tractor their is no relief on the added aux valve even if it so equipped, the remote pressure can back up against the backside of the aux valves relief valve and render it useless, the pressure on the front side of the relief would have to exceed the pressure on the rear side of the relief, ths would probably not be done intentionally operating both at the same time but it happens and new pumps are costly and they will split right open if the right conditions occour. This is a controversial subject and causes hard feelings but hydraulics has been my life, many say that they are hooked up with a simple valve and I do not doubt that but that does not make it proper. If anyone wants to discuss this further I will provide an Emai or Celll number
Regardless of what anybody else says...this is the way I did it 40 years ago, still works!
Mel I know you have seen many creative ways to install extra valves to the Case open center system as I have. As you and I know the correct way of doing so is as you
mentioned. The surprising things is I have seen some hook-ups that make you cringe and thinking man I can't believe nothing has been destroyed yet, lol. Oh well as time
goes by this will continue to happen, all we can do is grin and think damn you guys are lucky, Rod.
You can lead a man to a diversion valve, but you can't make him think!
I love the open center valves and the endless possibilities with power-beyond. I can even take power from my backhoe valve bank if I want. But yeah, all that oil has to go back to tank too.
I make doggone sure the hydraulic quick-connect couplers are zip-tie locked or things can go crack-bang.
This post was edited by WilBury on 02/17/2022 at 05:53 pm.
