970, spool valve
trak
No hitch or pto, removed spool valve, put air through it, always has air going through out port closest to supply, then will put some out furthest hole, not much or none center hole, which could be a return, also, in all the way closed position, seems like leaking air through the spool? Could O rings on the spool itself be what's wrong?
