99 Chevy Power Window
super99
I got a 99 Chevy 1500 Silverado from my Son in law. Drivers window is up and doesn?t work. The switch clicks but nothing happens. I took the liner off the inside of the door. I tried a wire from battery to the motor connection and got no results. I think the motor is bad. I called Napa,motor and regulator assembly are separate parts, not a complete unit. Can I replace the motor assembly still in the door or do I have to take the whole assembly out of the door to replace the motor. Window is up, so I can?t loosen the glass to take the whole assembly out. Now what do I do?
Ive seen times right where the big bunch of wires flex when the door opens and closes, there is a wire broken inside the insulation.
I sure wish you were closer to me I damaged a my 2ooo 1500 with only 500 miles on it. I still have the regulator complete with motor in GM box. I would give it to you. Before I traded the truck off the passenger side went bad and couldn't use the extra I had. just my luck. I worked on lots of them in shop, you will need motor, not fun to change the motor is riveted with 1/4" pop rivits to the regulator and they take an hydraulic or a manual long handled gun. I could even loan the tools if closer! When the regulator slides and rollers start getting wore they shoot the motor pretty quick.
I am dealing with the same problem on a Explorer. I can loosen the actuator motor and slide it out and separate the motor from the cable with the window up. they are available but make sure you get the right one. The co. shipped the wrong one to me under the correct description. The motor released and now moves up and down. I put everything back together and it likely will temporarily work until the window gets powered up and it stalls. Might have a dead spot in the motor. Had to park it until I can get an alignment done. Tires are not cheap when you have to replace all 4 at the same time.
Yea, wish you were closer!! Sounds like it would be easier to have the regulator out in order to change the motor. The window is up, book says to let the window down to unfasten and then put window back up and tape it in place. How can I move the window when the motor doesn't work??Looks like screws hold the bottom barrel of the motor on, if I can get them out, can I turn something and get window to move? Thanks, Chris
If your set on pulling it out a lot of times you can lean on the down switch and tap the motor with a hammer. Those regulators aren't hard to get out. About two bolts on the front and rear vertical track and they fold together like a scissors, don't remember exactly how the motor is attached though. Screws or rivets probably.
I started working on cars and trucks in 1959 retired 44 yrs later and I hate working on newer stuff, not like it used to be! I have been waiting almost a week for tractor dealership come and get starting issue fixed on 2014 5065. They made it out today wasn't what they thought, ended up being the starter its self, so I made a flying trip to one of their other stores to get one while the mechanic went to lunch, back in business now. Too much unneeded junk!!
Those window regulators are more than likely junk anyway, consists of a little cable and pulleys.
The motor has two terminals.
The internals of the motor do NOT ground to the motor housing so you have to make a connection to BOTH terminals to get the motor to run.
Did you ground one (to a good ground other than the door) and apply power to the other? That should run the window either up or down, if you reverse how ground and power are connected the window should move in the other direction.
I don't know if you have enough room to pull motor off the regulator without removing the whole thing. The 3 motor bolts come in from the back side and it mounts to the regulator and metal guide so at minimum you will have to remove 4 10mm bolts one beside the motor, the two for the guide (top and bottom) and one that pinches to glass. Honestly removing the regulator would probably be easiest since you would be almost there anyway. You don't have to remove the glass but can use something to wedge it up.
I had a Chisler Fifth Ave I had to use a piece of broom handle in the door to hold the window up when things quit working.
There is a guy in my town called Power Window Repair .I call him and for two hundred bucks he comes to my driveway and replaces tracks and motor.Very painless and worth it.
