Got what appears to be an original 9n still on 6 volt positive ground. I've changed carb and adjusted per manual specs..new gas line...new shut off and sed bowl...new battery...new coil...points...rotor and cap. She's hard to start most days...when it does start..generator is showing about 10amp charge on the low setting.. and the contacts close on the cut out. turn it up and the cut out opens and no charge on amp meter... put a plug light tester on it and at low rpm shows bright spark...but the higher the rpm it starts to send less spark and starts to miss..can see it in the test light and hear it backfire. Barely enough power to pull itself. Whats some ideas? This is just my toy and not the usual work tractors. Pulled the dist off and timed it per the manual instructions.. set plug gap (autolite 437) and points to the manual specs. Is it time to rip out the 6 and go 12 volt? Is it possible the dist is the problem and maybe the weights are not working properly...they did open when I had it apart to check points and timing.. New to this old girl and style tractor...so looking for any pointers.
