bobthetoolguy
Hi Fellas,
I need some help from you experts out there. I recently installed a Freeman Loader to my 1940 9N. I am using the 1/2"-20 Plugged hole that the IT manual calls the pressure test port to run the loader. I made a neat "banjo" fitting and included a hydraulic gauge in the circuit so I could see for myself what was going on. I was always told that the loader wouldn't go up until the lift arms went to the top of their stroke, however, I have found the following issues:
1.) The loader will not go up unless an implement is hooked onto the three point.
2.) Once an implement is attached, (I am using my grader blade) the loader goes up first, but not all the way. The loader never reaches it's full stroke, even after the blade reaches the top and the pressure gauge never goes above 500 psi.
3.) I performed the pressure test suggested in the IT manual and I weighted the grader blade down. My pressure built up to 1250 psi, the loader still went up first, reached its full stroke, then the blade lifted. According to the IT manual, it looks like I may have a bad safety relief valve, because it is creating turbulance at the 1250 psi point and I never reach the 1500-1700 psi range.
I know this has been long winded, but are these symtoms normal? I sure have spent a lot of time trying to figure this one out on my own, so I'm all ears if anyone out there can lend a hand! I can use any suggestion you might have.
