9N hydraulics
OtisP
I have a 9n with a hydraulic problem. The lift arms are in the up position (no drift, solid) and wont go down when the controller is moved and there is no resistance when moving the controller. I have removed the inspection cover on the right side and can see the "forks" and they do not move when the controller is moved to the down position. Any thoughts would be helpful.
Congratulations on troubleshooting. Some folks would have the top cover off and the pump on the bench by now.
You could have a bad friction disc or the control rod is loose from the pump. Take the inspection plate w/ the dipstick off. Reach in & make sure the control rod
is connected. If it is, move the touch control lever & make sure it moves the control rod. If the control rod is connected & the touch control lever doesn't move
it, the friction disc might be bad.
75 Tips
Too many years to rember details but there is a valve on pump that will gum up and stick that will do that, just take it out and clean it and put back. I had bought new valve and could see nothing wrong with old so cleaned good and still in tractor. Don't remember what I did with new valve. Over 20 years ago.
It could be the draft control spring adjustment. Had one last summer that the spring was just right (could just turn it by hand) but ended up was real loose. There was a wood wedge holding the draft control plunger forward. Removed the wood wedge and adjusted the draft control spring and all was well.
Another thing it could be is there is a spring that connects to the middle where the forks come together. If that spring is broken the forks will not return to proper position.
(quoted from post at 15:50:13 12/04/21) It could be the draft control spring adjustment. Had one last summer that the spring was just right (could just turn it by hand) but ended up was real loose. There was a wood wedge holding the draft control plunger forward. Removed the wood wedge and adjusted the draft control spring and all was well.
hat spring from mid-point of forks to end of cylinder must be there or it will not work.
