9n lift arms
Bought a set of Pats Easy Lift 3point lift attachments. His parts are sized for lift arms between 2 and 3 inches high. Mine are 1 3/4 which affects
the mounting. Only one set of the 4 bolts that squeeze the lift arm hits the lift arm. The wedges with the roll pin hole are not thick enough to
level the Easy Hitch. Had to make a couple of extra wedges to get the hitch close to level. My question is does this site or somewhere else sell
lift arms that are at least 2? high. This site only says theirs are the standard 32? length.
I ordered these from Rural King and contacted Pats at same time. Pats sent the longer pins at no extra charge.
My question still is the height of the lifting arms for 9ns. Mine are 1 3/4 high which are a little small for Pats device. I have installed them making some extra shims. Only 2 of the 4 alignment bolts hit the lifting arms.
(quoted from post at 16:22:10 09/02/18) Bought a set of Pats Easy Lift 3point lift attachments. His parts are sized for lift arms between 2 and 3 inches high. Mine are 1 3/4 which affects
As Hobo said, the people at Pat's were very nice about sending me the longer pins to accommodate stabilizer bars and another set of those spacers.
I only have the top horizontal bolts in mine and have lock nuts on them. On the big u-bolts, I put an extra locking nut on each leg with a lock washer under it. I've been using them like that for a couple years now and I never had anything come loose on me.
Occasionally, I will give them a check with a wrench but they have never come loose.
I suspect that you would have to get lift arms for a catagory 2 hitch to get wider lift arms but I'm not sure of that. But then they might have swivel balls for larger pins.
