Life is good when the old girl starts on the first crank, but lifting at her age has been difficult as years have progressed.
I"m hoping with a few descriptive words, someone like Zane can identify her symptoms and give me a place to start with out having to take everything apart.
Have a 4ft king cutter disc set attached to the 3pt hitch. Give her a start in the morning, about 65 degrees. Starts fine and idles nice. Engage the PTO and move the lift arm up, the lift arm starts to raise the disc set slowly and tops out at the lift limit. At this point the hydraulic starts pulsing and the discs set starts bouncing at the high limit. I slide it into gear and the hydraulic starts to lower by itself until the rpm"s come up while in gear.
Problems
1. Bouncing at the high limit
2. Raising slowly
3. Clutch disengaged or engine off, the hydraulic lowers by itself.
There are a few other inconsistentcies. Sometimes it cannot lift the load all the way to the upper limit. I can lift up on the disc set and "Help" the hydraulic lift up the disc set to the upper limit. Any idea"s on the diagnosis? Complexity of the solution?
This tractor is kept in a remote area and is used for food plots. I only see her about 4 times a year.
Problems
2. Raising slowly
