Just read in Hemmings classic cars,a statement in answer to a question,that Ford offered the 9n tractor engine in ford pickups and light trucks,in 1940 and later.Never heard of it before. Anyone else know about this.
I have no knowledge of the 9N engine being used in those Ford pickups but it is sure possible because it was used elsewhere. The Model A Ford car engine (1928-1930) was used; with little modification, in Model A pickups and trucks. The trucks were bigger and would have been rated to haul more than any pre-war pickup. The A and the 9N engines were very similar; both were flat head, four cylinders with up-draft carburetors. Neither used a fuel pump. The displacement was close. A difference was that the oiling system was “splash” on the A but “pressure” on the 9N.
The Ford A and B motors had a distributor on top the head. The 9N engine distributor is on front of the camshaft, like the prewar Ford V8s. The 9N is closer to half a Ford 60 V8.
I never heard of 40s vintage 4 cylinder Ford trucks.
Gerald J.
the 9n motor was used in trucks up to one ton, and in the first 2000 jeeps. it had a different cam and head. not enuf power.
The 9n was a much smaller motor than the A, yet capable of high RPMs. It was used in race cars after ww2.
I have seen early 40's Ford pickups with a 4 cylinder engine, surely was basically9N. At least that's what it looked like to me. I don't think it was a popular option and V8 is a lot more common
I had a ride in one. Not overly powerful with 1000lb. load. Intake valves were bigger and 40 hp at higher than tractor RPM.
Can you give me any more info on the Jeep connection? First I've heard of it, been around old jeeps a long time. Thanks.
the 9n jeep motor was labled the GP, as was the first 2000 g p (General Purpose) jeeps, none of which made it to combat.(all for training) Jeep was the name of a cartoon character in 1940.
The head and cam are marked GP. Any good ford or jeep book would explain this. All non-tractor 9n motors had a place for a fuel pump- off the cam.
The motor made 40 HP, and was very durable, but not enuf power.
Back in the 50s my wife's granddad had a Ford "Factory Remanufactured" engine installed in his 2N tractor. He had 3 sons and a son-in-law who were all Ford mechanics so getting this kind of work done was not a problem. I remember there was a fuel pump opening "blocked off" on the side of the block and I was told the block originally had come from an early forties Ford truck which I found kind of interesting at the time.
