9N pertronix failure
Ron Tron
installed new module after first one failed to produce a spark after sitting for a year and the new module works great for about 4 to 5 minutes and then the spark fails .......I guess I should go back to points. Whats nuts is I have two 9N's. The one I use all the time has a pertronix module in it for years with no problem. The second tractor I wired exactly the same and it fails to produce a spark.
Have you verified the coil or coil/resistor is correct for the voltage?
A coil drawing too many amps will burn out the trigger unit. They are also
polarity sensitive. I don't know what would happen if the polarity were reversed,
could burn it up or just not work.
Might try calling Pertronix, I hear they have excellent customer service.
The only Pertronix unit I ever had go bad was one I left the key on too long without the engine running. I have one in my MGB car that has been working for over 10 year. The one in my Ford 651 has been working for 5 years.
I am wondering them same , possible coil issue. It is not mentioned whether this 9n has been converted to 12v and whether a resistor is used, also if pos or neg ground. If everything is the same in the ignition system between the 2 tractors it would be easy to switch distributors/ coils etc to trouble shoot.
I have burned out two of them. One from leaving the key on while running the carb dry and the other was from a shorted coil. I would look at the coil. Make sure it is the correct type for the voltage of the tractor. The other issue is the type of ignition wires. You have to use automotive resistance type ignition wires or it will mess up the Petronix. I don't know if that would fry one or not.
OTJ
