9n pto shaft
we pulled the pto shaft out of the 9n... now cant seem to get it back in...whats the trick?
Wiggling, lot's of wiggling! :lol:
If it came out it should go back. Splines good? Maybe rock the tractor a little while in gear, trans & PTO. Make sure the key's off or battery unhooked!
ok the trick is to make sure the splines are lined up and push and wiggle at the same time when it goes in you will know it will but make sure theres no gears in your way make sure the path is clear to way the shaft goes.
