Jim Oregon
Hello,
I also have the same problem. I've got a 9n. The Marvel TSX 33. It would only run well with the choke out. I then had problem starting. It has sat for several months before I tried to start again. The carb was overflowing when I tried to start. I tapped lightly with a hammer and overflow seems to have stopped. After changing battery, sparying starter fluid and pulling the air cleaner tube it Started! But has same problem and it only runs well with the choke almost 90% engaged.
The Csrb is Marvel Scheble TSX 33. Front Mount distributer and coil. I think it is 1940.j Plugs are the autolite 437.
I've followed this string a bit. But I'm wondering if I should begin to work on carborator.
Another issue is oil leaks from the governor linkage approx. 20 drops in 1/2 hour.
Any advice is appreciated.
