9n starter brushes
Smokey37
what size soldering gun do I need to unsolder the brushes in the starter? Mine
won't touch it. I hate the thought of having to take to a shop.
I bought a little pencil type butane torch just for that very job, I believe I got it from harbor freight. You might even find one at home Depot. It worked great and was cheap.
Hello Smokey37,
Are you sure the gun is working?. Is there a way to tighten the tip. Thin the tip first. Melt a little solder first while holding the tip to the joint you want to unsolder, see if you get enough heat. Assuming you have good size iron?
Guido.
You'll need a good size iron, like a 175 watt or so.
I like the idea of the butane pencil torch, never tried it but would probably be lower cost than a big electric iron.
You need enough heat to get in and get out quick. Don't want to transfer too much heat into the windings, or let solder wick into the brush lead.
You need a good old-fashioned "soldering copper". You heat them with a torch, tin them, then apply them to the part to be soldered, for LOTS of flameless heat. I have a couple and use them every know and then, don't have a photo of them, tho, so here's one from the 'net...
<img src = "http://stellartechnical.com/images/213.jpg">
