9n starter button near the shift lever.
I removed the sheetmetal and gas tank to replace the water pump.
Water pump installation went fine.
Returned the sheet metal and gas tank and hit starter button to start engine and check for leaks.
Starter and engine turned over.
Fan shroud had bent in a little causing fan blade to strike it, so stopped cranking to adjust shroud.
Adjusted shroud, fan no longer striking it.
Attempted to start again and now starter button will not crank starter.
No adjustments or anything done to the electrical system other than battery disconnected while replacing water pump.
Attempted bypass of starter with jump pack directly to starter, grounded on frame. Starter turns over.
I know there is a starter "cutout" switch, but don't understand fully where it fits into the process. Could it have gone bad?
I haven't put the sheetmetal and gas tank back on yet as I don't want to have to remove it again to replace the cutout or something under there if required.
What might cause it to not work in between removing the battery terminal to adjust the fan shroud, since I did nothing to the electrical? Maybe just reached it's limit coinidentally?
Any help is appreciated.
