Hello. I am a newbie. This is only my second post;first about engine starting issues. I have been working on this tractor on and off since spring trying to get it to start and run consistently. Until now I have been able to research and follow along on others' posts about similar problems to mine for solutions, which has worked pretty well up until now. So now it's my turn to ask for guidance from the experts. The tractor is only used for occasional brush hogging a few acres of field, minor back blading to clean up snow and grading the driveway. Not heavy all day consistent use.
My tractor is a 1940 9N. Front mount dist/sqr coil and converted to 12 volts years ago by the previous owner. It has a Delco/Remy 3 wire alternator. Compression is 110 all four cylinders. My dad has owned the tractor for approx 25 years and really has done nothing other than fluid changes and spark plugs during that time. I seem to have inherited this machine with a renewed interest to get it running tip top. The tractor is located at his cabin property so I do not have daily access to it to trouble shoot my issues. but, I've taken many pictures and notes that I am hoping will provide answers to any follow up trouble shooting questions you may have.
As I stated above- its converted to 12 volts- and it seems to be wired differently than the diagrams I have researched; such as a 3 wire ignition switch- has three wires attached, but top position doesn't seem to do anything. Middle key position is off. Bottom position is "run". It still uses the neutral safety push button switch. Also, the ballast resistor only uses the the top studs- bottom has no wires affixed. I've tried to make some logic to the wiring set up and its similar enough to published diagrams that its beginning to make sense. Following the wires is difficult at times do to years of paint build up, taped or wrapped wires, hidden areas, etc.. The tractor has run fine until the past few years or so- but here's the issues and what I've done to attempt to fix.
I noticed last winter it ran better with the choke pulled out a bit, but this problem got worse as time past. I removed air intake and realized it had been running (seemingly fine) on full choke! I rebuilt the carb, put in a Tractor Supply "tune up kit"- plugs(437's)/coil/condenser/points/cap/rotor.....All gaps proper -double checked. It ran fine for most of the spring/summer. It began to have starting issues again- mostly just when the engine was cold and would run and start fine when warm. I replaced the cap, rotor, points (.015)condenser,plugs (.025) and cleaned the carb again (M/S 241TSX). It seemed to run fine once started, but still hard starting. Ive read that most starting issues seem to be electrical and I'm focused on that issue. It has good compression and floods when it doesn't start- so I know its getting gas. This past weekend I replaced the ignition switch with another 3 wire identical to the old. I replaced the ammeter along with the ballast resistor (A8NN12250B) and the inline ceramic resistor (8NE10306)-.6 ohms- This resistor was actually cracked. I did this to eliminate potential electrical deficiency points. After all this, it would still just crank but not start- maybe a sputter here and there. I was frustrated by this point. More at my lack of knowledge and feeling like I was just guessing now and throwing money at it. I'm mechanically inclined and routinely work on snowmobiles, quads, cars etc,,, But lack tractor knowledge/experience and really do want to learn.....
I checked my spark by using a new 437 plug gapped at 1/4". It jumped the gap with a bright blue spark at each cylinder- I did not expect that and it made me more stumped. So then as an experiment, I jumped the two posts on the Ballast Resistor and it fired right up immediately -like it was fuel injected! I immediately removed the jumper (screw driver) and it continued to run great. It did this several times as I duplicated the process. Once it warmed up, I didn't need the jumper for it to fire right up. If it had blue sparkkies before jumping, why did jumping the posts make it fire up so instantaneously? I looked at the test plug and cranked while jumped and the blue didn't appear any brighter?!?
As an experiment, I then tried to bypass the fixed inline ceramic resistor to see if maybe that was the problem and not needed. I turned the key on and saw that the ballast resistor was glowing bright red hot!! So i immediately disconnected the jumper from the fixed resistor. I'd never seen that ballast glow like that. Was like a light bulb element! At this point I'm honestly considering installing a switched jumper wire to the ballast resistor to turn on only when starting. I know that can't be the right answer but I'm frustrated and it seemed to work fine...What am I missing?? Sorry for the novel........Thank you in advance, Dave
