9N struggles with box blade
Taggart
Hey everyone,
I've been reading the great info on these boards for quite a while but decided to finally join in and post.
I have an early '39 9N and it just seems like the tractor is kind of weak. I have a 4' box blade and when I put it down, it's like an anchor. If the box blade fills with dirt, the 9N really struggles hard. I don't have weights or water in the wheels so that is contributing, but even so, it feels like the tractor isn't pulling what it should.
Or is this normal? This is my second tractor. My other has a lot more HP so maybe I'm just too used to that. Is it typical for a 4' box to make it struggle so hard?
The trouble with a 9N is that you do not have position control. It is either all the way up or all the way down. Even on my 8n I have to control how much is building up in the box. weight in the tires would surely help if you are spinning the tires.
Yeah, I'm currently building a position control jig to at least keep a set height to the blade. Been meaning to add water to the tires, but I haven't gotten to it yet.
Interesting to know that it bogs down your 8N. So what you're saying is I'm probably expecting too much without wheel weight.
I would not say it is bogging my 8n down, but it will sure spin the tires if I get too much rock in box, especially if I am going uphill. I do not have weight in the tires either. one of these day, maybe! For ripping out pot holes, a box scraper can't be beat!
well yes that's normal, they are basically an overgrown quad. they are not a pulling tractor. I remember the neighbor had one years ago. we were picking rock with it and loaded the wagon. then after the little ford would not pull if. just spun out in the dirt.
We may need to better define "bogs down"
and "struggles with".
To me those terms imply a lack of
horsepower. There are lots of posts here
about spark plugs being wired wrong and
the engine will run but have no power.
There is also the seperate issue of not
enough traction so the wheels just spin.
If your engine is running fine and will
spin the tires pulling a heavy load that
is a traction issue not a horsepower one.
Remember; a tractor can not put its full
horsepower to the ground without added
ballast. The tires just spin.
If that is your problem then you need to
add weight to your tires - either fluid
in your tires or wheel weights.
I'm a big fan of ballast. Both for the
increased traction it gives and for the
added stability it gives on side hills,
etc.
Also, what size is the other tractor you
mention using? A 50 hp tractor will do
more "work" with no added weight than a
25 hp tractor will even if the smaller
tractor has fluid in the tires.
Lastly, speaking of fluid, I believe
calcium chloride gets a worse rap than it
deserves. Tires, tubes and rims need
occasional maintenance just like
batteries, fan belts, hoses, tune up
parts and oil changes.
CaCl is still the most bang for your buck
when it comes to weighting your tires and
most farm tire dealers are prepared to
deal with it.
Ignoring obvious, visible signs of rust
around your rims and valve stems is the
culprit, not the CaCl.
I'm generally not too sympathetic when I
hear people cuss out the fluid because
they only got 50 or 70 years out of a set
of rims on account of the rust.
The local tire shop here will come out and load my tractor tires with Beet juice! Not quite as dense as salt water and a little sticky but apparently it does not freeze or cause corrosion. I have not done it yet, or asked for a price, but I do seem to spin my wheels a lot so I am leaning that way.
I say water but I mean Calcium Chloride. I agree, people fear it, but I've never had issues in the past.
We'll see what the ol' 9N does once I ballast this puppy up.
I'm also hearing some pops from a stuck valve every now and then so I'm keeping an eye on that.
(quoted from post at 17:52:48 04/14/20)
As Ultradog said, If you're spinning wheels you need weight. If the tractor is weak, could be lots of reasons.
Box blades can grab hard and pick up a lot of weight. Since you only have draft control, try easing up on the draft. Can also try adjusting the pitch of the blade with your top link.
Agreed with previous posts. If you have plenty of power and are just spinning the tires, it is definitely a weight/traction problem. At that point, adjust your top link (lengthen it) and take smaller/shallower bites. Ex: If you're cutting out a 6" lift, do it in 6 passes taking 1" each pass, not 1 pass 6" deep. Take your time and enjoy the time on your tractor.
If your tractor just flat doesn't have enough power to pull the box blade, it could be one of two things. There again, take your time and make several shallow passes, not one deep cut. If you are doing light work like grading your driveway and your tractor won't pull a 4' box blade I would say its time for a rebuild or at least a tune up and make sure your firing order is correct (1-2-4-3). That tractor should handle a 4' blade doing light work with no problem. My 2N is pretty sick (low power and lots of blow by) and it will pull a 5' box blade to do my driveway.
