9n water pump leak
OtisP
1940 9n replaced water pump gasket and the pump leaks at the top. The provided gasket is a half moon shape with no gasket at the top of the pump. Is this correct?
The half moon gasket goes between the block and the water pump cover then there should be a full circle gasket (P.N. 8507) that goes between the cover and the water pump.
Looks like who ever you got the pump from forgot to include that gasket. :(
(quoted from post at 12:16:02 10/08/21) 1940 9n replaced water pump gasket and the pump leaks at the top. The provided gasket is a half moon shape with no gasket at the top of the pump. Is this correct?
Thanks for the help. My lack of knowledge was the problem. The part number was a huge help
