9n Wont Turn Over
Willracin
Cranked Engine was running fine moved out of barn and switched it off and the trouble began.1940 9N wont turn over or even try to. Things I ve tried so far. Battery is fully charged. (Still orig 6Volt sys and most wiring is stock) Battery Cables replaced. Starter fresh rebuild and works as it should on the test stand. Tried jumping across start switch and still get nothing. I am at a total loss. Also engine is not locked up.
Clean the area where the positive cable attaches to the chassis.
Pull the starter away from the block & clean the mating areas bright & shiny. (see tip # 36 first)
Then, jump it as described in tip # 43.
Post back w/ results or more questions.
50 Tips
