A-C Dual Fuel
GaryinKs
Does anyone know anything about an AC dual fuel tractor?It has a propane tank and a gas tank , it looks
like a WD -45 but I am not sure, any idea of the value? it looks like it is in good condition.
LP WD45 had a front mount LP tank that utilized the mounted cultivator brackets- the square cutouts that were referred to. They mount on the front of the C-channel frame. You could switch from one fuel to the other.
Never too old to learn--just looking at tractordata.com, I see three compression ratios listed for the WD45 226 engine. The common gas, a lower ratio for "tractor fuel"(I suppose the true dual fuel-start on gas run on distillate) and a higher ratio for the LP model. I assumed the gas tank was just used on the WD45 LP as a dummy to hold the hood. Probably cheaper than coming up with something else.
Used to be lots of WD45's around. No LP's here. Very few diesels.
When I was a kid, about 65 years ago, a friend of my Dads was running styled WCs on propane, don't know if they were dual fuel but seemed to run ok on propane.
