I'm hoping some of you can help me make a decision.
I bought a TO35 a few years ago that wasn't functional. I went through it and fixed everything necessary to make it reliable. The problem is that I have a lot of trees, hills, and there is no power steering. When using it for my main purpose, the loader on it, it is a bit hard to use.
My property is wooded mostly. I used it to help clear some smaller trees and stuff but it really seems under powered for what I need it to do.
I bought a barn in a box(30x42) and I have a lot of other things I need to do. My property, in TN, has some hills and stuff. The MF is great as far as physical size goes but I feel like I need something stronger. I don't really use implements aside from the loader but if I had front hydraulics I think I'd appreciate many of the loader style implements. I'm split between getting a larger tractor, an older backhoe, or a skid steer.
I have never owned a tractor other than the 35. I see a lot of tractors like the Kubota B21, 2360 Long, Kubota 3710, Case 685, etc. I see a lot of skid steers that seem to be in functional condition. I also see things like the old Ford and Case backhoes that are more like mini excavators. I see all of these between $5-10k pretty regularly.
The probably is I'm not sure what I'm looking for to be honest. I see skid steers clearing land with apparent ease but I have no concept of the sizes and such. They all look the same to me essentially. I get HP differences and track/vs wheeled. Tractors have a similar issue for me. I get that 4wd is preferably for loader work probably and for land clearing.
Does a 50-60hp tractor do what the skid steer will? How does the Case 685 compare to a 90s-00s skid steer? How would it compare to my TO35? A foot wider and 2 foot longer?
I could rent a skidsteer but I have never even been in one. Being a complete novice, I'd probably have to take a week off and then pay for rental to get everything done. That is 1/3-1/2 the cost of a older gas skid steer. I'm not against buying one for more and then reselling it after I finish everything up. However, I feel like a skid steer could probably do all the work I do with the tractor anyway and more. I'm really not sure the size and reliability of the different machines to know which ones to look for. My F150 can pull about 9k lbs, so anything over 6 or 7k I'd have to get delivered.
Any thoughts you could give me as to the best path for my needs?
