jon f mn
Did a little more plowing last night, was pretty wet but this field is and so it went. There was so much water that water would be in the furrow when I came back around. Lol. The problem was this is the field one of the previous renters had put up fence in, then took the posts but left the wire lay. I found the wire first with the brush mower earlier. I pulled out all the wire I could find before starting plowing, but obviously missed some. Found this the first round. Walked the field again after that and found more, but still missed some because I kept finding more with the plow. Must have cleaned the plow off half a dozen times. Hopefully I got it all now. Supposed to rain again sat. and sun. so I hope I can get more done the next two nights. This ground needs to be fall plowed or you can have a real mess.
