I had to put a new separator clutch disc on my Gleaner K2, it started slipping and the old disc was flat wore out. According to the manual you turn the adjusting plate counterclockwise to adjust it, i've attached a photo of the instructions in the manual. While i had the assembly off I cleaned everything up and made sure the adjusting plate would turn easily, funny thing is.....if you turn the adjusting plate like the manual says it unscrews and will come totally apart. I just wonder if that is a misprint in the manual?? To tighten the clutch I will have to turn it clockwise, anyone else run into this??
