A piston install problems
CP4010
what do i use to compress the piston rings to install them. i have never seen a ring compressor that big if thay make one where can i get one any help will be a big help thanks
I bought a cheap on from auto zone for my 50 A When I put new rings and had the head redone. I worked just fine. Now only if I can get the darn carb going. You might want to buy 2 I broke mine on the 1st piston
Try borrowing a compressor from an old Deere shop, if there are any left, or maybe even a truck shop. Today most of the piston/sleeve sets for engines that have bores that big come with the piston already in the sleeve, but a shop that works on the bigger engines might have a dusty old compressor laying on the top shelf somewhere.
I got lucky and bought a couple of them cheap at the auction of an old Deere mechanic years ago. Jim
I've used a rolled piece of smooth sheet metal and a couple large hose clamps on more than a few occasions.
harbor freight has them prolly nothing i would use if i was makin a living from it but in your case its kinda a once or twice use any way
