A Steering Arm.
Jensensix
Hi, I am a high school student and I am restoring a 1945 Case DC-3 through the JB Dewer Tractor Restoration Program. Right now I am working on the front end, and the steering arm I have has two plates welded to it, and it needs to be stock. Does anyone have any ideas how to make it look stock? Or does anyone have one that i could buy?
Thank you.
Couldn't see the pic. If it is a round arm/shaft,Simply cut out the bad area and weld in new stock. grind smooth.
Delta has a great idea. The weld must be stronger than the original break. If welded with inclusions or a heat affected zone that could cause it to
fail, it is dangerous. If it proves to be a hard part to find, Call Yesterdays Tractor to see if they have one. Jim
Welcome Jensensix!
That is a scrawny looking arm, I can see why it needed to be reinforced!
Your choices are, leave it until you find a good one, cut away the plating and try to weld it up, grind it down, or cut the ends off, weld them to a new piece of round stock.
But chances are it is a steel forging, which would be stronger than a piece of 1018. maybe some 4140 would give enough strength, it welds nice.
Link Link
Those rarely break, I have never seen one welded. There are
plenty available at salvage yards or from collectors that you
could get. Go down to the case page and ask there and I'm
sure someone will have one for you. You will need your
tractors serial number as there are at least a couple different
ones. One tell is if the arm that runs along the side is straight
or turns in towards the front. If you can't find one I can get one
for you. One place to call would be Gotvald IMP in Pierz mn.
(320) 355-2500
We don't know if he is referring to the draglink that extends down along the hood to the front or the arm you pictured. The one that you referenced is much beefyer that the pic looks. I have never seen that arm broken. I am presuming he is referring to the draglink and it is torn out at one of the two ball joint ends and has been reinforced there.
Pics would be a big help forsure.---------------Loren
