About had enough
gab
of these Onan engines, last time I mowed last fall I parked in the shed and walked away, no sign of a problem. Got it out Saturday to get it ready to mow and the top of the deck is all oil as well as the frame
I figured it was the crank seal I relaced over a year ago but that was dry. Oil sending unit was dry and the filter adapter gaskit looked good but I replaced it anyway. oil filter was tight but had to be the problem.
I took all the tin off the engine to wash the oil out, but my newish pressure washer died. I scrubbed it out best I could with a stiff brush and solvent and it cleaned up pretty good.
Oil filter had 44 hours on it, seal looked good. I hate putting all that tin back on but it started right up. The old girl has a little more than 2000 hrs. on it. wonder what it's got left
Most of the old Wheel Horse mowers I've been around had a Kohler in them, good machines. Luckily the only Onan I have is in my 646 Case. Onan is a good engine, but parts are expensive.
Two years ago while snowmobiling in Northern Maine, we were gassing up in a small town at 10:00 PM with still two hours to go to our stop for the night. I noticed an oil leak under the front of my sled with 140 HP Suzuki turbo. It turned out to be the filter which I had replaced 400 miles earlier.
I bought it last August only used a couple times and a fancy brass fitting blew off the bottom.
It's under warranty, a new one is being shipped, I'm just trying to salvage the old one.
