I had been losing prime a few times so I changed the filter, checked fuel lines, bowls, transfer pump, etc. After changing filter I lost prime two more times, now I can't get fuel to the injectors.
I get good flow from the bottom bleed screw in the injector pump but not getting up to the injectors. Only get dribbles at the #3 injector and none at the other two. It also was spitting out unburnt fuel through the exhaust.
It seemed to lose prime or stall out when going up a steep hill. Tank is half full. Each time I got it primed, it ran fine for a day or so. Engine oil is clean.
Thanks,
WM in NY
Thanks,
WM in NY
