ac 175 hydro oil
chad9999
I split the tractor and had to drain the the pan with the pipe going to the front pump I got about 2 or 3 gallons out but I don"t know where to put it in. I found the dip stick near the seat and it checks full. even after starting it up and working the hydro it still checks full and the loader is jerking(low oil).
As you're sitting in the seat there is another dipstick to the left of the shift lever, that is for the hydraulics.
looked everywhere can not find this one.. the only one I can find...as your sitting on the seat it is just below the seat on the right
If it is like my 170, as you're sitting on the tractor looking down near the gear shifter, there is a mushroom shaped dipstick for the transmission/differential to the right side of the case, and a nut shaped dipstick to the left for hydraulic oil. It is a threaded dipstick and you may need a wrench to turn it loose.
