AC 7030 transmission problems
Anonymous-0
I posted this on the AC forum but have not gotten any responses so I thought I'd try this forum that seems to be more used. Our 7030 worked fine yesterday but when I got in it to disc this morning it will not shift in to the high or low range (turtle/rabbit). The stick shift in the floor works fine and the lever seems to go in low range position but nothing happens when I let out on the clutch. The lever will not shift into the high range position. My guess would be a linkage problem but I'm no mechanic. Any help is appreciated.
Take floor plate out & be sure that dirt hasn,t built up under the pedel that rocks back & forth.Good luck.
