Looking at a guys "48 AC-C. Heres the deal. Not much on AC"s. Tag # 1-21-48 narrow front. Block # around core plug on right side is 1 AM 291621. Right side tranny inspection plate 200964. Left side tranny # isAM 2990 oil level 3284. Now the nasty part. Wiring screwed won"t start. Sitting for 3 years. no cracks around block anifreeze in radiator. Needs seals around front axle, grease everywhere. Clip missing on air cleaner,need new one? Seal onaxle housing to tranny leaking down. Wheel on left side wet. needs all pto housing seals. Sheet metal good, been repainted once before. Minor rust. needs brakes. Hole in hood for temp gauage? Thanks for any help.
Serial number on a C is just forward of the shifter. Those number you gave are casting numbers only. As for what it is worth I picked up one like that a few years ago for $450 but it came with a sickle mower and the rear tires where very good. I would say around $250 give or take a little bit
