AC Model M, and loading M, and disc
37chief
Location
California
This is my AC Model M, and the AC disc, I use for discing. Dad did discing for others, while farming also. He loaded the tractor the same way for years. This is the 54 chevy truck my Dad bought new. It turned 100,000 a couple years ago. All hard miles. It only gets a little scarry when one of the planks brakes half way up. Don't know how many more years I will be doing discing. With the price of insurance, and license it almost doesn't pay to disc.The only place I use the disc now is where there are a lot of rocks. mowing is much easier. Just mow and go.Stan
(quoted from post at 09:55:35 01/22/13) This is my AC Model M, and the AC disc, I use for discing. Dad did discing for others, while farming also. He loaded the tractor the same way for years. This is the 54 chevy truck my Dad bought new. It turned 100,000 a couple years ago. All hard miles. It only gets a little scarry when one of the planks brakes half way up. Don't know how many more years I will be doing discing. With the price of insurance, and license it almost doesn't pay to disc.The only place I use the disc now is where there are a lot of rocks. mowing is much easier. Just mow and go.Stan
Man I do like the M. We had one that grand dad bought back in the early 40's. Yours looks to be in pretty good shape. Don't suppose you would want to part with it?
as one truck maker's logo go "built ford tough", HOWEVER; those models of chevrolets are considered to be the toughest, especially 1954 due to it fully pressurized, inserted 235 ci engine. nice truck!
I thought I was the only one that had a crazy grandfather. I don,t remember much about the loading but my job at 8 to 10 years old was sit in the truck and hold the brakes when he unloaded in the same fashion. I can remember my head bouncing off the celling in the F6 Ford. His dozer was some kind of oliver that looked about the same size. He would try and find a ditch or bank to back up to but if not unloaded about like that.
You could chock the planks 1/2 way on the span, I used to moonlight with the company flatbed at the lumber company I worked years back, moving cars, using spruce scaffold plank, the actual 2"x10" not nominal lumber. Without columns or braces it would load a car such as a early 70's or late 60's Buick GS, flex a little but I made up some short pieces and put them in the middle of the span, you just have to inspect the lumber you use, OSHA outlawed these for scaffold around this time or a little later.
You are probably so used to that crawler, loading and unloading, nosing over, probably does not scare or intimidate you, though the feeling of something dropping out from under you is always present. Our young foreman whom was in charge of us doing site work /excavation decided one morning real early to try his hand at or better himself on the JD 850 dozer we had on site. Just as I came up over a rise, with the tractor trailer-lowboy, I see him nose over a berm and get launched out of the seat onto the hood, just about kissing the stack, Phew....... glad he did not get hurt, good guy too, not the only tryst, I had to hand dig him out of a trench collapse once too, up to his neck, wind knocked out of him, some people have 9 lives.
Scariest crawler incident I had was on a Caterpillar 977-L. We had this nice addition to a private girls school outside of Morristown NJ, the site work, and had a huge pile of fill to remove, some days I'd just run the 977 loading others would be both, tandem dump and load yourself out each round. I try to align the trucks in a simple K pattern to the bank of the pile, easier on U/C wear, and the operator etc. So just as I get over the sideboards with the bucket, the ground collapses under the front end of the track frames, bucket now on the sideboards, back end up in the air, operator of the 225 excavator up above backfilling a retaining wall swooped down in a panic, the whole job stopped, and eyes were on us. I thought about what to do, and figured out what how I wanted to get out of this jam ! I carefully walked the 977 back until you could stand under the drawbar! No lie or bs, not my "schtick" to ham things up anyway. I wish I had a photo of this one. This gave me enough room to move the bucket which was still 3/4 full from being heaped up full, maybe now full but struck full. Point is its heavy, and with the combination of walking back even further and curling it all the way back, getting those teeth up, I was able to get it over the sideboards, and just ride the side of the dump box, which was old anyway, all the way down to the tires, which by then the bucket teeth wanted to dismount, I backed up further, the back end was a lot lower and got out without a hitch, apparently there was an unknown tank or void in this spot and I found it ! The other workers on site, hoot & holler, clapped as the performance was over and was back to work, was a little scary, cooler heads prevailed.
Sounds like you put on a good show all right.I know things happen real fast. I am going to install a seat belt this year, as I have almost been thrown over the hood a time or two. Stan
No Stan No.... don"t do that anymore. I rolled a D2 off a truck back in "83, nearly killed me. You need a long low tilt trailer like an Eager Beaver.
I used to take tractors for a ride on trucks, no more.
Nice Model M I love them, I have one in the shed that needs work.
Here's mine the day I brought it home from an auction. I had never driven one before, so got a quick education when I went to load it on my trailer (which has steel ramps). I got halfway up the ramps and one track started slipping, then it grabbed, then the other track, then the front end reared up and the process started all over again. I wasn't used to the over center clutch and was lucky the thing didn't flip over on me. I got it backed off the ramps, and by that time a crowd had gathered :) One guy came up to me and said that I needed some rubber belting, and pointed to a lowboy down the row that had a couple of rolls on it. I horsed them over, laid them on the ramps and drove the crawler right up.....learned a lesson that day and fortunately lived to tell the tale.
BTW, I hardly ever use it and it could be bought.......
I helped my brother load his OC-3 Oliver on his '52 F-5 Ford flatbed once. He blew a bull gear so it was only driving on one track. We had his Massey-Harris 444 chained to the bucket on the dozer. We could go about a foot then I would pull the dozer sideways with the tractor to straighten it on the planks. Kept it up until we got it loaded. Then we had go down a lane so steep we chained the tractor to the truck to hold everything back. We were 35 years younger then, he might do it again, I sure wouldn't. But we both would like to have that old truck again.
There are times a seatbelt is good to have on, I'll bet Mikey, as we called him wished he had his fastened that morning, though you need a rops if it was to overturn, one of those will keep you in the seat an not kiss the stack LOL !
PS,nice looking A-C, I'll bet it does the job and then some when using the disc, I saw the photos of it stuck and I thought southern california was arid and dry, I guess you have mud holes like us too LOL !
