AC question
sodly
Please bear with this AC newbie. What was the first AC tractor (under 100 hp) to have an independent PTO? I mean, on the D series when you pushed the foot clutch the PTO stopped turning. What was the first AC tractor that the PTO continued operation even when the foot clutch was depressed? Did any of the 100 series tractors have this feature?
The One-Sixty/160 had a two stage engine clutch, both stages being controlled by the foot pedal. This tractor was AC in name only as it was built by Renault.
There were no D10-D12's around here, so I have no experience with them. I believe they got up to a series III, so changes were obviously made. I don't believe live PTO was an earlier option, but came later, as with your tractors.
Early generation D10-12's did NOT have a live or independent PTO, but they did have a PTO. I believe it was the Series 2 and 3 models that had a truly independent PTO similar to what Oliver used.
(quoted from post at 06:24:10 01/11/19) Early generation D10-12's did NOT have a live or independent PTO, but they did have a PTO. I believe it was the Series 2 and 3 models that had a truly independent PTO similar to what Oliver used.
The reason I bring this up is because I've often fancied owning a D-series or a 100 series tractor but would need to be able to do chores like bush-hogging with it. However, I'm told the Power Director really makes that difficult if you have a lot of backing up to do. The foot clutch kills the PTO every time you step on it to change from forward to reverse-- not ideal with a mower behind you.
So the later D10 and D12s have an live PTO where you can push the clutch down part way to stop the tractor without stopping the PTO? But the D15 and D17 tractors did not?
Were there any other later AC tractors (besides the 160) that had this ability? Or an independent PTO that ran regardless of the foot clutch? The 170... 180... 190... 200? I'm not that familiar with all of them and how they differ from one another. Not interested in a foreign-built model.
I don't know how the later D10-D12 PTO was engaged. Whether a two stage engine clutch, or a separate clutch in the rear. A look at the parts diagram would be instructional. I will guess it's a separate clutch, as I don't recall AC using a double clutch.
The D14-15-17-19, as well as the 170-175-180-185-190-190XT-200 all worked the same way- engine clutch stopped PTO. Use the "power director" to maintain PTO operation.
Anything with the Hi/Low Power Director clutch kills the PTO when you step on the foot clutch. For those of us who are used to it, it's not really that big of deal when the tractors hydraulic oil is fully warmed up. Many times you don't even need to step on the foot clutch to shift and if you do it is very quick with no time lost.
(quoted from post at 08:27:46 01/11/19) Anything with the Hi/Low Power Director clutch kills the PTO when you step on the foot clutch. For those of us who are used to it, it's not really that big of deal when the tractors hydraulic oil is fully warmed up. Many times you don't even need to step on the foot clutch to shift and if you do it is very quick with no time lost.
Thanks for the update guys. That's what I suspected.
Dr Allis, you can shift from forward to reverse without the clutch?!!?
(quoted from post at 17:50:00 01/11/19) I have a number of A/C tractors. On my WD45 you can shift form forward to reverse using the hand clutch but on my D-17 I cannot do that.
Interesting......
I can't with either my WD or WD-45 but I can with the D-17 if I do it quickly. That works out well as I do most of my bushhoggin' with the D-17.
(quoted from post at 10:31:39 01/11/19)
Interesting......
How is this even possible if the tractor is rolling forward to shift into reverse without the (foot) clutch? Or vice versa?
As you can see, it's not so much the model, but it's conditional factors. You can shift with the power director, or hand clutch, if, the tractor ground travel is stopped, the oil is warm, your clutch is in good working order [no warped plates] your shifter is in good condition, you're fast, and know what you're doing!
sodly ,the d-10 I refer to PTO has nothing to do with the foot clutch. It is independent. It has it's own control lever behind the seat and nothing you do with foot clutch affects it. No 2 stage clutch.
I see your concerned about backing up with a bush hog. An overrunning coupler on the pto helps a great deal. not perfect but you can clutch and shift pretty quick. use one on my 185. I think cost about 100.
Around the middle of 1961 the D10/D12 tractors came with an independent pto. At the same time they went to a 12 volt electrical system and a larger engine along with an increase in power. AC didn't start putting series II decals on these two models till 1963.
There was a version of the D15 (if not others) on which the Power Director lever was forward and reverse, not 2 speeds. It would be ideal for what you're doing, but they're kind of a rare bird.
