oldfarmall
Hello-
Well here is the story. I just got done putting a new engine clutch, ta clutch, and other parts in my Farmall 450 gas tractor. Went to drive it home Saturday from my friends house where we worked on it in his heated garage. Did not know if I could make it all the way home, so I stopped at the local Mobil gas station in town. Put 5 gallons of Super + premium unleaded gas in. Went down the road about a mile and noticed that when tractor bogs down on hill or when I shifted the TA in road gear it was blowing brownish dark smoke out exhaust. Did not smoke before I stopped at the gas station. Also, smelled a bit like diesel exhaust, not burning oil. The engine smoked a bit on hills and under load the rest of the 30 minute drive back. When I got back I shut it off. About an hour later, I started it up to put away in the barn, smoked constantly and alot until I shut it off, smelled of diesel, was a bit hard to start. Tonight I tried starting it, would not fire without starting fluid. Got it running, and smoked constantly again.
So, I drained all the fuel out of the tank. Next I started it up and let it run completely out of fuel. Refilled with 5 gallons of unleaded gas from our tank on the farm. Smoking went away shortly and engine ran fine when I went up to the woods and back. No more smoking under load or at all.
So, question is, did I do any damage to my engine? I saved the fuel I siphoned out. Any way to test my theory that it was diesel at a gasoline pump? Is diesel at the pump clear in color? I am supposed to be getting a call back from the gas station owner tomorrow. Needless to say, I am ------, as I just spent $1500 on the repair for the clutches. Hope I don't have to stick any money in the engine now. Thanks for any thoughts in advance!
-Jesse
-Jesse
