rossow (mn)
I'm trying to revive my oxyacetylene setup after several years (six or seven) of inside storage but non-use. The acetylene tank's gauge shows plenty of gas, but the pressure-regulating gauge needle sits dead at the zero side. (It's not pegging out in the red zone as bad gauges may do.) By adjusting the valve -- carefully just a tiny bit -- and listening I can hear the pressure change, but the needle doesn't move. I suspect a faulty gauge that hasn't been used for quite a while.
My question: Is there anything special about unscrewing the gauge and replacing it (with tank valve closed, of course) with a new one?
FWIW, the set is a tiny Craftsman outfit from the late '60s I have used for heating up rusty nuts and doing some thin-metal welding and brazing. I've rarely used it for cutting anything. The gauges are 2" diameter, and the gauge thread appears to be 1/8 NPT. An actual Craftsman replacement is, I'm sure, long deceased, but other 2" gauges seem readily available. I've never had anything apart other than to change tanks and to change tips. I don 't want to screw something up if a gauge replacement isn't as simple as I hope, and your expert advice is welcome to help me avoid a big boom.
(Interesting sidebar: Many years ago an O-ring was leaking in the torch, so I went to the Sears parts department to get a replacement. I was told their parts data showed no specific O-ring for that torch and I'd have to buy a whole new torch. So I asked if they had generic O-rings. "Yes, of course we do" -- and so I bought one for a dime -- 10 cents -- and it worked perfectly for years until I set the equipment aside, and it's probably still OK today.)
