Bruce from Can.
- Location
- Woodville, Ontario, Canada
I dont know your budget but if you are wanting a
loader tractor, to move snow and move bales, I would
be looking at a 4wd tractor. While there were some
4wd tractors available during the 1970s , they
became very common during the 80s . I have had 2wd
tractors with loaders, and yes you can get by with
them, but tire chains and rear weight on the 3pth is
necessary, or you will sit and spin, while being stuck
on nothing once you pick the loader up. Particularly
with a bale on the front end loader. Personally I would
stay away from gas tractors. They were all built for
gasoline that contained led, and not ethanol. If you
can plug in a diesel, they can start every bit as well as
a gas tractor will. I have owned several IH and CaseIH
tractors over the years. and I found the 584-585 684
685 and the 884 -885 tractors to be reasonable
tractors, but I would only buy one that has a shuttle
shift, as the dry clutch models will go through a clutch
every 1500-2000 hours. Biggest downside to the
IH/CaseIH tractors in this series is the fact they have
one common hydraulic fluid, for
transmission,hydraulic, and brakes. And brakes
particularly the parking brake as they wear, do put
particulate in Hydraulic fluid. And unless you use the
CaseIH Hytran or a similar high temperature hydraulic
oil, the brakes will deteriorate very quickly . I have no
experience with JD equipment, only to say if you do
look at JD, buy a tractor that was built in USA. Not one
from Mexico, or Germany. They are all the same
colour, but not all equal in quality. Engines,
transmissions and particularly hydraulic pumps
gallons per minute will not be the same. JD built in
USA tractors will be very good, and they will cost
more. You only get what you pay for
