Adding a spool valve to Ford 3000
jmandrze
I am looking to add a single spool valve to our 3000 to make moving a few things around an easier task. I prefer the bolt and go route. I found two and was wondering if anyone had any experience with either one or had an alternative solution that they could recommend.
Here are the two I was looking at, I was leaning more towards the broken tractors model.
http://www.brokentractor.com/ford_hyd-aux-valve.htm
http://www.thetractordoc.com/shop/remote-hydraulic-valve-kit-ford-single-spool/
Thanks,
Jason
Soundguy,
I assume PB is power beyond. Would this be the adapter plate? https://www.external_link.com/atpcart/index.php?main_page=product_info&cPath=38_40&products_id=1752
And this an appropriate valve?
http://www.mscdirect.com/product/01825785?src=pla&008=-99&007=Search&pcrid=15557577904&006=15557577904&005=21882504424&004=4409695744&002=2167139&mkwid=sJXegN7a0|dc&cid=PLA-Google-PLA+-+Test_sJXegN7a0_PLA__15557577904_c_S&026=-99&025=c
Thanks for the information and potentially saving me some $$.
Jason
Soundguy,
Jason
your links won't connect for me.
something like thois plate:
http://www.yesterdaystractors.com/Ford-3000_Hydraulic-Adapter-Kit_HV4902.html
and perhaps soemthing like this.
open center single spool, set as sa.. etc... plenty meet your needs..
http://www.surpluscenter.com/Hydraulics/Hydraulic-Valves/Directional-Control-Valves/1-SPOOL-PRINCE-HCSVG0002-LS3000-LOG-SPLITTER-VALVE-9-1262.axd i'm sure you can find better.. this was a quick search
The one from the tractor doc for $437.90 is a pretty good deal and it is an easy bolt on with no extra hoses to run and you won't have to find a place to mount the valve.
Mark
Neither would be my first choice.
I would just buy a used remote valve from someone and put that on. I just sold 2 singles here in the last couple of days. $200 each.
