Adding loader vavle to a 1970 2520D SyncroRange
SWMO Chris
I have a 1970 2520D syncro-range with a model 48 loader. Currently the loader is using the SCV"s to supply hydraulic oil to the control valves that are mounted to the loader. I have to keep the SCV lever pulled back to supply oil to work the loader valve body. I want get away from this set up and Tee into the hydraulics for the rockshaft. I do not have the line by the brake pedals like my neighbors 3020D has. Where do I need to hook into to accomplish this?
It's good to see somebody want to properly connect the loader instead of some quick and dirty slob solution.
Any place you can find an elbow and replace with a "T" on the high pressure line. Between the front pump and the rockshaft or SCV valves is good.
While the Waterloo chassis chassis has a much better supply from the trans sump to the front pump. Than the dubuque/mannheim tractors.There are ported filter covers that replace the ordinary trans filter cover. And provide a return port for loaders, backhoes, log splitters and in particular hydraulic motors.
(quoted from post at 23:18:46 06/12/11) Where do I need to hook into to accomplish this?
The later model 20 series Rowcrop tractors aren't as easy to tap into the hyd's as some of the models. If it was me I'd tee into the rockshaft supply line under the hood in front of the firewall.
I put a T in the line running from the front of the firewall to the rockshaft....under the platform. It works great. I brazed a elbow into the filter cannister for the return line.
I have a 2520 gas with a 148 loader. There is a metal hydraulic line that runs under the platform to a pressure control valve under the cowling (just to the right of tachometer). I replaced the metal hydraulic line with a hydraulic hose and tee-d in between the hydraulic hose and the pressure control valve. Works great. If you need me to shoot some pics, just let me know.
