Adding remote hydraulics to YM155D
Thanks to all the answers provided here so far. On my little 155D I see there's a block just in front of the shift lever that appears to be some sort of access to the hydraulic line. I'm looking to add a fwd/reverse remote hydraulic system with quick-connects at the back to run a hydraulic rototiller I have from another tractor. Does this block allow for some standard sort of connection/lever setup?
It can probably be done (I'm not familiar with that block), but plumbing it wrong can cause damage, and at best it would take work and money to install the lines and connectors.
That is called a diverter block. Instructions for using it are hard to come by. It is made for auxiliary hook ups but as Alan has stated be careful not to dead head your pump.
The block itself is just a hollow pass through right now. When yanmar added a loader or other piece of equipment they removed the cover from the block and added a piece that bolted to the block that had fittings that allowed for the extra hydraulic circuit. Without Yanmars bolt on piece it will really not do you much good. I would just cut the lines and use compression couplers if I were me.
<ATTACHMENT filename="155.JPG" index="0"><s>[attachment=0]</s>155.JPG<e>[/attachment]</e></ATTACHMENT>
