Adjustable spanner.
Geo-TH,In
I have many adjustable spanners. None work as well as this one.
I guess everyone is missing the fact that the adjustable wrench is drilled at the jaw tips and has roll pins to use as a spanner to take apart hydraulic cylinders. Looks like a good idea
(quoted from post at 11:40:13 01/02/22) I guess everyone is missing the fact that the adjustable wrench is drilled at the jaw tips and has roll pins to use as a spanner to take apart hydraulic cylinders. Looks like a good idea
My guess is they aren't missing that fact, they've seen it shown multiple times before and are poking at George.
Repairing hydraulic cylinders is why I made it.
Have a tool box full of other worthless adjustable spanners,
One cost me $50.
And it is both SAE and metric.
Flip the wrench over and it metric and Then SAE.
I have had many cyls that them spring pins would shear off. I have couple of spanners,1/2 drive and 3/4 drive and needed swamp stick on them a few times.
If you have larger cylinders, I'll bet your pins will have larger holes.
My spanner that connects to 1/2 ratchet requires 3 hands, 1 to hold the spanner, one to hold the ratchet and a third hand to hold the wire.
Mine works best for me.
Always, use what works best for you..
You make fun but growing up all adjustable wrenches were Crescent Wrenches because Crescent was the brand that was out
there. So fast forward to a few years ago I bought several different sizes at HF. Getting home I noticed that on one side it was
SAE...flip the wrench over and it was Metric on the other side. Only on a couple of rare occasions did I buy said wrenches where
the tumbler was indexed where it couldn't vibrate to a new setting, you had to turn the tumbler.....I think they all should be like
that.
Where I worked management cautioned employees about using company trade names to identify the functional noun describing
products we manufactured whereby company patents might be/could be compromised. Case in point is Crescent for adjustable
(spanner) wrench, Kleenex for facial tissue,
