I"ve built a front blade & frame for our 2N for my folks to use to push snow this winter (Dad had a hard time turning around to watch a back blade). Everything is done and mounted except for the hydraulic lines - I put a single-acting cyl out front to lift the blade - and I"m wondering if anyone has any advice about which way I should go on this.
I"m going to tap off the hyd test port under the right footrest (yes, we"ll chain down the lift arms). I have that hard-to-find fitting already. But how fancy should I get with this after that fitting?
Some say to just hook the line straight from that port to the cylinder and use the 3-pt"s control to raise/lower. A couple of guys have told me it"s been done for years like that and it sure sounds simple. But I remember Zane cautioning against this, saying that the N"s internal relief valve isn"t designed for that kind of use and its seals will erode & start leaking. I don"t think anyone has been into the hyds except to flush & fill the system, so I"m concerned about stressing an already-old part (the 3-pt works just fine now) and I sure don"t want to have to pull the top cover in the wintertime to fix it . On the other hand, how much is "lots of wear?" Dad will be pushing maybe 500" of snow, and here in SW Ohio, we"ve been getting only 2-4 decent snows each winter.
The two other choices I see are:
-- Plumb in an adjustable relief valve, set at a lower pop-off pressure than the N"s internal valve (I believe another Wise One on this board said that"s around 1200 psi). The relief side of that valve would dump back to the trans/hyd sump, either thru the fill plug or the side cover.
-- Use a single-acting cyl valve (open center) with dump to the sump just like a relief valve would do. The 3-pt"s control lever would then be left in the up position, to provide pressure all the time (except when the clutch is pushed in ). The SA valve should also be one with a load check. (Or use a DA cyl valve & just use one side of it).
Any thoughts or advice? We"re normally on the newer Ford board (for our 3000) but we started out here years ago when we got our 2N, our first tractor. Sure have learned a lot from this site"s forums. Thanks in advance.
