The interesting part of this question comes about with the OP saying he wants to run motor loads from this aux valve. Power beyond and motor control don’t always play well together. When using a power beyond valve, it diverts flow to the application from the downstream valve. So if you cycle the first valve full on, there will be no flow to the secondary valve. Works fine if you only ever want to use one function at a time.
Plumbing 2 regular valves in series, can cause a multiplication of pressures. The pressure of any functions operated simultaneously is added together, and hydraulic cylinders have the ability to increase or decrease the available pressure depending which way they are fed. Any motors in this type of setup need to be on the last valve in the circuit, or you risk blowing the shaft seal out due to back pressure.
I would recommend to use a flow divider or flow control like this:
The line from the pump would go to the inlet of the flow control. The controlled flow line would connect to the aux valve, and the outlet port would feed the original valve. Plumbed like this, the flow control is acting as a priority valve that can be controlled by the operator.
In regular use, set the flow control to 0 and the loader will work like it originally did. If you are using the aux valve for a cylinder, the flow control can divide the pump flow between the two functions, the loader controls will slow down depending how much volume is sent to the aux valve.
To run a motor off the aux valve, the flow control will set the motor speed. On something like a mower, it would probably take most of the hydraulic flow, but you can leave a little going to the loader valve so you can still adjust the position while the motor is running.
