Afraid to try to start.
manya77
Over the last weeks I have had great help with my geriatric 9n from members of the forum. Many thanks to all.
I replaced the obviously ravaged wiring harness, battery/starter cables, starter switch. I had removed the battery so I could access the wiring. Now I am reading about polarizing the cutout ?? EEEK.
I am at sensory overload. I need to understand how I should proceed step by step once I replace the battery(positive ground).
Thanks,
(quoted from post at 16:32:02 06/17/15) Over the last weeks I have had great help with my geriatric 9n from members of the forum. Many thanks to all.
Thanks,
ust take a length of wire & touch it to un-grounded battery post to the single generator terminal, you will see a small spark, you have now completed polarization.
When you do like JMOR says, you are polarizing the generator not the cut out. The cutout does not need to be polarized, it is just a convenient place to do it for some people.
If you are saying that you're afraid to start the engine due to
the polarization, don't worry a bit. That is your charging system
and won't affect the starting and running of the tractor.
It will only (maybe) keep it from charging the battery.
I just read your posts on the cutout. I've not seen one like that.
All of mine look like the one JMOR posted.
With your improvised attachment points, I would watch it for
battery drain when it is shut off, maybe disconnect a battery
cable at night if not sure. If it turns out to work fine and not
drain the battery when it is shut off then you have succeeded!
IT STARTED RIGHT UP !!!!!! I just watched the connections
for a while. cables all felt cool. Now to the overheating issue,
will start a new thread after I read in the archives.
I am so relieved after the frustrations of the past year when nobody local would help me I want to start it up just to enjoy the sound. I only use it to mow the house lot of an acre as needed by rainfall, and a conservation lot of 10 acres for woody growth twice a year. All is done with a bush-hog, this ain't no country club. Should I start it up and move it around anyway even if I do not want to mow ? How often ?
I brought the new battery into the basement last winter, it is 20 below sometimes here . It is parked in a barn in Sep and started up again in May. Appreciate advice.
"Should I start it up and move it around anyway even if I do not want to mow ?"
Many people do and I don't think it hurts them to be ran at all.
But if you do, don't start it and run a for only a few minutes.
Run it for a while after it gets to normal operating temperature.
Otherwise it won't be warm enough to get rid of condensation.
